Lintronic - Use your Beo4 for non-B&O products !
Lintronic
Although not a Bang & Olufsen product, Lintronic is widely considered revolutionary when combining B&O systems with other products. From the incomparable TT455-RT-238 to the well-known lightdimmers, Lintronic are the people to speak to!
Lintronic on the Forums
Frustrated that you can't make it work? Do you have new codes you'd like to share with the BeoWorld community? Tell all in the BeoWorld Discussion Forum!Want more information on Lintronic? - visit their Website by clicking here !
Created: 15th January 2007
Modified: 26th March 2007
