Beolink®MasterLink 2 |
BeoLab 3500
is an integrated link room speaker consisting of an active speaker with Master
Link (ML) connection, an IR receiver and a display. BeoLab 3500 also has Master
Control Link (MCL) connection. Furthermore, the BeoLab 3500 has a built-in
clock. The BeoLab 3500 is supplied with a mains lead and a bracket for wall
mounting.
Application
BeoLab 3500 is used in link rooms where you wish to have an integrated active
speaker. From the BeoLab 3500 it is possible to listen to all sources from the
main room, both audio and video sources. BeoLab 3500 has built-in sound control,
meaning that tone and volume can be adjusted independently of the main room.
With the tone control it is possible to adjust balance, bass, treble and
loudness individually. BeoLab 3500 offers the following local operation
features:
Part nos:
Miscellaneous: Besides the parts included with the BeoLab 3500, the installation may require a Master Link cable as well as plugs. sockets and junction boxes.
BeoLab 2000
Link (ML) connection, an IR receiver and close-up operation. BeoLab 2000 is
supplied with a mains lead and a bracket for wall mounting. BeoLab 2000 is used
in link rooms where you wish to have an integrated active speaker. From BeoLab
2000 it is possible to listen to all sources from the main room, both audio and
video sources.
BeoLab 2000 has built-in volume control. meaning that volume can be adjusted
independently of the main room and offers the following close-up operation features:
Part numbers:
For further details of these products please see the main BeoWorld site
BeoTech © 2006
All rights reserved
