Beogram Drive Belt Replacement - Where to buy?
You can obtain drive belts for later Beograms from your official Bang & Olufsen Dealer as a special order Spare Part, or you can try your luck with independent suppliers.
However BeoWorld would recommend that you contact Dillen on site. Dillen is one of our moderators so we do have a certain bias but he has long been involved in the world of B&O even prior to BeoWorld being set up. He can supply many belts and also capacitor kits for many B&O products and his knowledge of the products of the 60s,70s,80s and 90s is unrivalled.
If you find any more manufacturers of older Beogram parts - please let us know and we will check them out and add them to the list!
Reference: 19
Created: 15th January 2007
Modified: 24th August 2010
