Can I get replacement pads for my Form 1s?
Yes! Your dealer should still be able to order these for you, but there is a conflict of opinion as some dealers are saying they are no longer available and cannot obtain them...
The set comprises of 4 pieces, two for the actual driver setions - and the other two that rest against your temples. Sponge rot on the Form 1's is a common problem, so don't feel as if yours only have let you down!
Reference: 38
Created: 1st March 2007
Modified: 7th March 2007
