How do I use my Beo4 to work Sky or cable?
To do this you need a Set Top Box controller (STB-C) fitted to your Beovision and the correct software installed.
Older STB-Cs may well not have SKY+ on the pick list and will need upgrading. Your dealer can advise on the current list of boxes supported.
Reference: 46
Created: 1st March 2007
Modified: 7th March 2007
