My Beomaster 5500 works but produces no sound!
Check which speaker sockets are being used. If Speaker 1, try pressing the right side of the front of the Beomaster.
This is the Mute button. If it clicks, but nothing happens, try the speakers in the Speaker 2 socket. If that works, the problem is the mute relay which needs replacing. A relatively cheap fix!
Reference: 47
Created: 2nd March 2007
Modified: 7th March 2007
