My BS2 won't write to my SD card.
Often this is because the SD card has been used in another device like a camera.
The card needs to have all hidden files deleted. The BS2 will not do this through simple formatting, so you will need to use a separate card reader.
Reference: 65
Created: 4th March 2007
Modified: 6th March 2007
