What do the Potentiometers on the front do?
These are the adjustment screws that are used by the factory to fine tune the speakers to ensure a flat frequency response. they are also used if you are unlucky enough to require a new drive unit to match the amplifier to the new unit.
Some customers like to alter these themselves and they are your speakers to do with as you wish. However remember that B&O have spent a fair amount of resources delivering your speakers to you in what they regard as perfect balance. The advice is to twiddle at your own risk!
Reference: 70
Created: 4th March 2007
Modified: 6th March 2007
