How do I change the region code on the DVD1?
NOTE: This method does not make the DVD1 Region-FREE. There is a limit of FOUR changes to the product over its lifetime (without professional servicing.) USE THIS INFORMATION AT YOUR OWN RISK.
Remove any CD or DVD and disconnect the power.
Press and hold << and >> on the front panel (not the remote) while reconnecting the power plug.
The current setting shows on the display.
Use << or >> on the front panel (not the remote) to change Region number.
Press PLAY to store. Wait 15 seconds until TV screen shows blue.
See http://en.wikipedia.org/wiki/Dvd_regions for information on specific regions.
Reference: 78
Created: 30th March 2007
Modified: 30th March 2007
Thanks to matheyl.
