How can i tell if my BeoCom 2 is a Mk1 or Mk2 ?
You can tell at a glance the difference between the Mk1 and Mk2 versions by simply looking at the actual and of the phone that sits in the charging base.
The BeoCom 2 MK2 release was at the end of 2005. Take a look at the picture to the right which shows where to find the differences.
Reference: 94
Created: 7th October 2008
Modified: 7th October 2008
